Hi, I need some help with converting SYSWIN program to CX-Programmer. The PLC I'm using is "CPM1A". I can first do a download to the PLC with the old SYSWIN codes, and afterward do an upload from the PLC using CX-Programmer. Everything works fine except one instructions cannot be converted properly. It is the "PULS(--)" set pulses instructions. In the old SYSWIN codes, it uses Port Specifier: 0 Control data: 4 Number of pulses: 0 And in the CX-Programmer, the Control data doesn't allow you to use 4 as its value as they only allow 0 or 1. (SYSWIN allows you to use 0 to 5) I was trying to hunt down any old manuals that allow me to define that control data number for SYSWIN, however I was without success. I tried both value 0 and 1 for control data but doesn't seem to work. So my question here is does anyone here know how I can go about converting this change without errors and will still function the same as SYSWIN? Many Thanks
Guest anonymous
Hello pizzaboy, Both the Port and Control data should be set to 0 for CPM1A. It will be an error within Syswin if it allows anything other than 0. Manual... http://downloadcentre.omron-industrial.com...3C6ED107172DAB5 Hope this helps.
