ratcliffe_ic Posted February 3, 2008 Report Posted February 3, 2008 Ist post in the siemens Section. What do I need to get online with an S7 300 PLC. Haven't got the exact model number, sorry, but it was installed last year. I have some leads (232 with a converter) and software for S7 200, will this do the job? Thanks in advance.
Moggie Posted February 3, 2008 Report Posted February 3, 2008 You will need the software for the S7 300/400 range of PLC's (Simatic Manager) as well as the MPI adaptor. The S7 200 range of PLC's use completly different software and adaptors to the S7 400/400. Siemens have finaly caught up with other suppliers and can now supply an interface cable that will connect to both the S7 200 or the S7 300/400 PLC's. For alternatives to Siemens have a look at www.process-informatik.de
Groo Posted February 3, 2008 Report Posted February 3, 2008 The S7 200 is a totally different PLC, so not compatible as mentioned above. Depending on how you connect. The basic is MPI, you would need a serial to MPI converter I believe there are USB converters as well. All the PLC's I connect with have ethernet, so that's how I connect. If you have Profibus, you can also connect via Profibus, the same lead as MPI I believe.
Rod_Hackney Posted February 5, 2008 Report Posted February 5, 2008 There use to be a limited version of S7 programming software you could download from siemens website. It could not work on a network but if you connect directly to MPI port with their cable it works well enough for stand alone applications.
