Hello all, Let me say first I am very new to logic controllers. I have learned alot reading all of your posts. I am trying to interface an old air compressor plc (Mitsubishi FXo-14MR-ES) to a solid state hybrid rocket motor, (school project). I have 4 solenoids to control all very simple, on at # off at #. The problem I am encountering is I do not know how arrange my pins on the cable (mini 8 DIN connecter to 9 pin serial) that I have to build to link up to the computer. I have downloaded the manual but it does not get that thenical, any sugestions? Edited by housed
You will probably have to buy a cable for mitsubishi, most have some form of interface conversion circuit built into them so you cant just make a cable. i.e. Q cable will not work with an FX, FX2n will not work with FX0n
Programming cable part number is SC09. It has electronics in it to convert the PLC RS422 com port to an RS232 you can connect to your PC. There are threads here where someone was able to reproduce the cable cheaply without the electronics. You should search existing threads for an answer when possible. http://forums.mrplc.com/index.php?showtopi...gramming++cable That thread has over 70 replies... it's been here a while...
They also sell them on ebay (not made by mitsubishi) for that plc very cheap (£20)
