Husanto Posted April 8, 2008 Report Posted April 8, 2008 Hi, any body how to connect siemens cpu315 to proface using 485 communication ? can give me sample program in PLC and Proface?? and connection cable. Thanx Husanto
Rod_Hackney Posted April 8, 2008 Report Posted April 8, 2008 A standard profibus cable can be used to connect a Siemens S7-300 series processor to a proface display. The Siemens standard port on the S7-300 is Siemens MPI protocol. You can get the profibus quick connectors from Siemens as well as the profibus cable.
Husanto Posted April 17, 2008 Author Report Posted April 17, 2008 i means i want to connect it using 485 protocol? what the configuration cable can i use??
Rod_Hackney Posted April 17, 2008 Report Posted April 17, 2008 If your connecting a S7-300 PLC to a proface display, the profibus cable and connectors will work. Although your not running profibus, the wiring for MPI is the same. I have a S7-312 Siemens PLC connected to a Proface model AST3211 using th Siemens profibus cables and quick connectors and it works fine.
