iic_hyd Posted April 18, 2008 Report Posted April 18, 2008 Hi, I want to control two out puts by using one input, i.e. when input is high 1st out put should become high, again second one and this cycle should continue, please suggest how to control with out using timers or counters. Rg. Ns.
Fredrix Posted April 18, 2008 Report Posted April 18, 2008 (edited) What software/hardware are you using? When the input goes low again, do you want the outputs to go low? Edited April 18, 2008 by Fredrix
iic_hyd Posted April 22, 2008 Author Report Posted April 22, 2008 Hi, Thanks for your reply any how you can consider S7-200/SLC500. Infact there will be a cam which rotates and activates Limit Switch and th Limit Switch will be on for more than one sec.which is sufficient to drive solenoid, main problem is with very old hydraulic system in this we need to control turret index, for this there are two Solenoids , when we power up we can on any Solenoid to index but next time we need to on the other one again first one, this is the sequence. Regards Ns.
