roscho Posted May 5, 2008 Report Posted May 5, 2008 Hello, I have a job that i am installing a plc to replace some old controlle cards that are not suppported by the oem any more,but it also has a melsec plc f1-20mr that i would like to leave, but need cable to do some programe edits, but can't find any info on cable. any info (pinout/were i mite be able to buy one) thanks for taking the time read.
Gambit Posted May 6, 2008 Report Posted May 6, 2008 You need a F2-20GF1 and a SC02N cable. Don't think you can buy them anymore though
Rodney Posted May 6, 2008 Report Posted May 6, 2008 Roscho The original cable for the "F" series P.L.C. was the SC-03. But the SC-09 can also be used which is the one that is available today from your local distributor. However you ask for pinouts it is not just a simple cable it is a converter as well. What you will also require and which is no longer available is a F2-20GF1 interface unit. You may be lucky if your distributor may lend you one. Good Luck Rodney
