Hello, I using Siemens Step 7 software. When I open a DB-block in the data view and click on the monitor button I can see the actual values. When I close the monitor button the actual values are zero. How can I save the actual values in the DB-block so I can see later in offline the values? And when I have many DB-blocks how can I save the actual values? Greetings, mulderm
- open DB in your offline project - click on "open offline/online partner" (one of first icons - do NOT click on monitoring glasses!) - click on Save - close window
Thank you for the fast response. And when I have many DB-blocks I must open all the blocks one for one and save it one for one? Greetings, mulderm
Hello! I use the method of "drag and drop". Go to "on-line-container" of all blocks, highlight every block you would transfer, grabb them and drop in the "off-line-container". Best regards, Mape
