edpuente Posted May 23, 2008 Report Posted May 23, 2008 Hi: I had use in the past the simulator to test my programs, but now I want to access to it, and it doesn´t allow me to simulate. Any ideas where to start? Thanks for your inputs Edgar
Carol Posted May 23, 2008 Report Posted May 23, 2008 Hi Edgar, it might be a problem with a Windows update or something with the windows register. Try a search for "simulator" in the Omron section, you're not the only one struggling with this problem. I tried the registry entry that was posted by anonymous (http://forums.mrplc.com/index.php?showtopic=11917&hl=simulator)and I've no further problems with the simulator. Hope this helps, carol
BITS N BYTES Posted May 24, 2008 Report Posted May 24, 2008 Just ran AutoUpdate for April 2008. Indeed CX Simulator failed to run after the update. Tried registry changes suggested by both anonymous and pszczepan in post http://forums.mrplc.com/index.php?showuser=5154 Registry changes suggested by anonymous did not solve problem. Registry changes suggested by pszczepan worked perfectly. Thanks to both for their help!
