I have a Wonderware Intouch 9.5 Application at one of our facilities logging production data to a Microsoft Access Database. It is a standard Wonderware implementation but after running for two weeks it just quit logging. The particular machine I have it on is running Microsoft XP service pack 1. Anyone ever run into issues like this with Wonderware Intouch and MS Access?
I think may you have problem in your database file. Try to close your HMI, the open your databse file by MS-Access, repair and compress your database file. If you still have the problem, check the following points: 1-Check if your windows still have DNS definasion into your database file (Start\CP\Administrative tools\data Sources ODBC\) 2-Open your HMI project folder and check if all your tags link defination are there in SQL.DEF file. 3-Open window maker, and check if all tags link defination are ok in Bind List and Table Template
