Mike2008 Posted June 9, 2008 Report Posted June 9, 2008 Hi, First post and new to PLC's... I have inherited a Mitsubishi FX-32MR-ES/UL and a copy of GX Developer Software. Can I program this PLC with this software? When I open the software and am asked to select a PLC type from the dropdown menu there is no 'FX' selection. There is FX0, FX1, FX2 etc.. but no FX?? Do I need to get different software?? Thanks, Mike.
Rodney Posted June 9, 2008 Report Posted June 9, 2008 (edited) Hi Mike2008 Your P.L.C should be one of the type as you have mentioned in your post. You should see the type on the front of the P.L.C between the FX and in your case 32 which is the number of I/O. Rodney Edited June 9, 2008 by Rodney
Mike2008 Posted June 9, 2008 Author Report Posted June 9, 2008 Rodney, It is an old enough PLC. Is it just an FX-32MR-ES/UL. There is no 0, 1, 2, 3 after the FX. I am just wondering if I can use the GX Developer software to program this 'older' PLC? Mike.
Gambit Posted June 9, 2008 Report Posted June 9, 2008 (edited) Mike You should use FXU/FX2C. But there is an easier way when you do not know which PLC type to Choose. You can let the software choose for you. Do not create a new project. Online => Read from PLC You only have to select the series (in this case FXCPU) and the communication route. Press connection test and it will have selected the right CPU type. Edited June 9, 2008 by Gambit
Mike2008 Posted June 9, 2008 Author Report Posted June 9, 2008 Folks, Thanks for that. I will try that tonight. Many thanks again and I hope to be able to contribute in the future.. Mike.
Rodney Posted June 9, 2008 Report Posted June 9, 2008 Mike I have just checked some old software FXGP/WIN and that also asks for a P.L.C type. Gambit suggestion will do the trick Rodney
Mike2008 Posted June 9, 2008 Author Report Posted June 9, 2008 That worked fine. Thanks again to all. Mike.
