PdL Posted June 20, 2008 Report Posted June 20, 2008 I was wondering how to get the symbols from my Step7 Micro/WIN program in my WinCC flexible tag list. I tried using Excel to copy paste but that does not seem to work, neither can I export to a *.csv file from MicoWIN. Is there a clever way to go about this or do I have to enter them one at a time?
tashinz Posted November 13, 2008 Report Posted November 13, 2008 (edited) HI PdL, I have the same problem now. I have a step 7 project and building a wincc application for tp377 operator panel. i can use tags from step 7 as the wincc project is integrated into step 7 project but since the tags are like DB_AI_M14.SENZOR_008.offset and there is M01 to M21 and senzor_000 to senzor_008 it would be easy to use find/replace feature. but i can not type DB_AI_M14.SENZOR_008.offset into some I/O field in wincc if that isn't already in the wincc's tag list, and of course, it is on the wincc tag list only when i select for that I/O field in wincc a tag from step 7 project. so i need a way to import all tags from step 7 project. any ideas? Edited November 13, 2008 by tashinz
