Didro Posted August 6, 2008 Report Posted August 6, 2008 Hello All ! We use FX3U PLC and our customer wants to use UPS. When power supplier is down, PLC should sent message by GSM-modem. We plan to use simple APC Back-UPS (320VA). But our PLC has only one RS-232 port, and we already use it. Could we somehow connect UPS to PLC direct by PLC's input terminal? Thank you
Crossbow Posted August 6, 2008 Report Posted August 6, 2008 Most industrial grade UPS units have a relay output which indicates when running on UPS power. I used a Mitsubishi UPS on a project years ago. I took the relay output and wired the relay contacts to turn on a PLC input to indicate it was on UPS power. If it doesn't have a relay, and you're not able to use the RS232, what way would you expect it to indicate to the PLC it was on? Only thing I can come up with is wire a relay to the output of the UPS and one to utility power, and then look for the UPS one to be on and the utility power one to be off.
