Dave46 Posted September 11, 2008 Report Posted September 11, 2008 hi I am trying to get GX Developer to connect to ENET module on FX3U rack over WAN I have tried port mapping to the IP of the ENET on 6004 & 1281 does anyone know what port I should be using to connect to the ENET module, is it the Transmission Target port setting in the FX Configurator? thanks
Crossbow Posted September 11, 2008 Report Posted September 11, 2008 You should only have to make sure that one of the 8 connection channels is set to TCP Melsoft Connection.
funfrok Posted September 22, 2008 Report Posted September 22, 2008 Melsoft connection port number for FX3U is 5551. You should port forward TCP port 5551 to PLC.
ETR Automazione srl Posted September 23, 2008 Report Posted September 23, 2008 with this port i work in SSH in tele service with FX3U over internet... Check also the configuration of the module. Bye
