shalan Posted September 26, 2008 Report Posted September 26, 2008 I have a problem with download programm to PLC by CX Programmer 7.2. When I compile this programm, everything is OK. But than during the downloading it shows the message (2.pdf). An error message is in 3.pdf. Could anybody help me? Thanks. 2.pdf 3.pdf
Automation Posted September 26, 2008 Report Posted September 26, 2008 A little strange but, it proves of removing the comment of that line 5, and to compile again. In all ways, I would take advantage to upgrade your CX-Programmer on-line.
PdL Posted September 26, 2008 Report Posted September 26, 2008 Have you tried changing the download options for comments?
PMCR Posted September 26, 2008 Report Posted September 26, 2008 If I remember correctly, this was an 'undocumented feature' in this build of CX Programmer. PDL is correct, an online update should upgrade you to a version that fixes this issue. Also, changing the program check options (in the menus PLC / Program Check Options) should fix this in 7.2 Select 'Custom' and uncheck the 'For/Next' checking. If that is not the right option, remove them one by one until it the program will compile.
shalan Posted September 27, 2008 Author Report Posted September 27, 2008 (edited) Thanks for your help, I will try it next week during checking of the technology. Edited September 27, 2008 by shalan
