Goody Posted October 2, 2008 Report Posted October 2, 2008 DORLUX_MAT_PACK_V1.rar Help with file registers I have programmed mitsis for years and thought I knew pretty much all I ever needed to know. So last week I was called to a customer that had a machine that was misbehaving. This machine is a matress packer with a fx1n 40 and a 16 output extra module The hmi is a LENDHER (which I can find no information about) The company makes beds and this machine wraps and seals the mattresses with polythene. The mattress come down a conveyor and the packer straightens it, wraps polythene around it heat seals one side then moves it down to seal the other sides. The straightening action is timed to give a value to tell the part 2 sealer how far out to move the 2nd sealing bars. (the matresses are all different sizes) It has worked ok for a few years - now sometimes the second sealers dont get the information from the first and so do not move and then miss sealing the polythene. Now the program (which I have attached below) is either very badly written, well it is anyway - or I am missing something huge in my education. of course - no such thing as comments or drawings - the only things marked are what I have added. I just couldnt follow the flow of this program so I have brought it to my office to play with so I dont mess anything up I have put the program in a spare fx1n40 I use for just these things. So firstly, file registers - I have never ever used them but my understanding is you set aside some memory for the file registers and the values in them stay with the program - not just the plc. you access them by using BMOVE to put them in normal D registers But apart from this program that jumps around all over using STL programming in a most uncoventional way The BMOV instuctions are baffling me. For a start (if you look at the program) the bmove is moving 8 registers at a time always in to start address d100 - ------------ - - - d101 d102 dont exist anywhere in the program (maybe they are used with the hmi that I cant get into) in the character string (when looking at memory) there are things like alarms written which dictate the values in the file registers. - but almost the entire memory has been allocated as file registers but only a few seem to be used. I dont think this is the problem with the machine - but I do need to understand what is happening. I wrote a test program with file registers and the strangest things happened The only way I could get values into them was by using device test I then saved the program and got an extra file registers option I cleared the plc memory and reloaded the program (including the file registers) and the values I had put in were there. But I then tried to change them by looking at memory devices and I couldnt (well I could but they didnt show in the program) also, if I wrote words in the character strings at the end - the whole registers changed value but not in the program??????? Can anyone shed any light on the use of file registers... :(
Veganic Posted October 3, 2008 Report Posted October 3, 2008 You seem to have understood everything quite well. What bit are you stuck on? This may be saying what you already know but : From the FX2 'handy' programming manual: -------------------------------------------------------------------------------------------------------- Consider them 'read only' changed only by a program download. ------------------------------------------------------------------------------------------------------- Don't any of the following strings appear on the HMI? ERROR EN D3/D4 ERROR ON PHASE2 INITIALIZATION ERROR ON S3 NAPAKA VAR STRAN WORKING READY MACHINE STOPPED DOOR OPENED EMERGENCY STOP The Bmov moves the above strings to D100-D108. D102... do exist in the program implicitly in the BMOV. They are not used anywhere else in the program as they are for the use of the HMI only. ------------------------------------------------------------------------------------------------------- The file allocation could be a typo?
Goody Posted October 6, 2008 Author Report Posted October 6, 2008 Thank you veganic for your reply (sorry for the delay in mine) It helped that you confirmed what I thought - and in this case the file registers are all for the hmi warnings etc. I am still not easy with file registers though (not this program but in general) They dont seem to play straight! :) Like; - there is no instruction to put values in file registers - so it seems you have to POKE each one in by hand. Thats ok - you can go to device memory and put them in by hand. But, if you want real words in the character string (as a mnumonic to help you know what the registers are for) the values in the registers change and as far as I can tell, they are either in hex or 32 bit???? after using character strings and bmov-ing these values into ordinary registers - they dont work correctly using math manipulation. (they do work correctly without using the character string - but in the program I am using they have character strings) I am only interested in teaching myself all about file registers and have done some extensive testing of them over the weekend with some totally unexpected results. At the moment - although I can now see some merits of file registers, I dare not use them in anything I do in the future without a solid grasp of them and, it would seem I am not alone stumbling around in the dark here - by the amount of views and d/l's of the program. Maybe we all need to find some definitive answers here :) 1
Veganic Posted October 6, 2008 Report Posted October 6, 2008 To be honest I've never found a use for them. They just seem to be D registers made difficult. 1
Goody Posted October 8, 2008 Author Report Posted October 8, 2008 Lol Veganic, and I, after much testing and playing and struggling etc have come to the same conclusion. Maybe their best use is for memory retention after a long power down, I dont know! (who programs with a thought that the machine might be unpowered for 6 months :) )
Crossbow Posted October 8, 2008 Report Posted October 8, 2008 Since file registers can be stored on a memory card, another purpose of file registers is portability. If the CPU dies (which of course doesn't happen) the values in the R registers can be stored on the memory card with the program and simply moved into a replacement CPU. And their purpose is long term storage.
