Hello, I have a Eplan project named with the extension p. Example: project.p I can not open it with Eplan P8. Is this created with another version? Why can I not open it? Greetings, mulderm
Try changing the extension to .elk, .ell, or one of the other extensions P8 typically works with. I'm not sure why your project has a .p extension. Do you know who manipulated the file before you? Hope that helps. Designer71
Hi, If I remember correctly, thos are Eplan 5 projects, which can be imported into Eplan P8, but not exported back afterward. It's a one way process. Look under the Project menu, you will see the EPlan 5 import options. Regards
