Guest bly Posted February 10, 2004 Report Posted February 10, 2004 Hi ppl can any one tell me if i can read and manipulate a 314-cpu using siemens step7 lite any help tia bly Quote
Klaus Posted February 11, 2004 Report Posted February 11, 2004 Yes you can! Cut from siemens homepage. STEP7 Lite is designed for non-networked automation solutions. Typical applications are those with SIMATIC S7-300 in a centralized arrangement with digital and analog inputs/outputs. SIMATIC C7 and the intelligent probes of ET 200 S/X can also be programmed. LAD, CSF and STL are available as a programming standard. In terms of simulation and diagnostics there are no restrictions compared with STEP7. If the tasks should become more complex, you simply upgrade to STEP7. Your investment in the know-how is secure, as your data can be transferred. Quote
Guest Fritz_frederix Posted February 11, 2004 Report Posted February 11, 2004 Hello Klaus, Were do I find some more information on Step 7 lite? Thanks in advance Rudi Quote
Klaus Posted February 11, 2004 Report Posted February 11, 2004 (edited) Fritz here are some links containg more information.......... Step7 Lite Siemens support Siemens mall Edited February 11, 2004 by Klaus Quote
