profmaster Posted January 21, 2009 Report Posted January 21, 2009 Hi all, I need help to program my servo driver. Somebody can help me. I want modified servo speed. Before, it run pulse, but now I want to continued running. I trace wiring connection from servo driver to PLC. My servo driver I/O, connected to RS232. Whose know bout this? PLC type CQM1 CPU 43 Thanks.
bluebyu Posted January 21, 2009 Report Posted January 21, 2009 Do you have the manuals? What is the model number of the drive?
Sleepy Wombat Posted January 21, 2009 Report Posted January 21, 2009 Since it is a CQM1 CPU43 it will be more then likely a 15pin connector on the PLC which is definetly not RS232... it is the High Speed Counter and Pulse Output connector from memory... I strongly suggest that you get a copy of the manual first. RTFM and come back with some more informed questions then. Have you even looked at the ladder logic yet ? For a hint look for the PRV, SPD, ACC, commands in the ladder logic for starters.
profmaster Posted January 22, 2009 Author Report Posted January 22, 2009 Can give pin configuration or some else? What the manual that I need to refer actually?
Sleepy Wombat Posted January 22, 2009 Report Posted January 22, 2009 CQM1 Operation Manual W226-E1-7 CQM1/CPM1/CPM1A/SRM1 Programming Manual W228-E1-7
profmaster Posted January 23, 2009 Author Report Posted January 23, 2009 Hi, can somebody give me the simple ladder to accelerate the step motor. I need to do the modification to my machine. previously, the stepper run step-by-step. now, i need to make it continues run until i press stop. I already download the manual, and I tried the example given, but it not work. I don't have any experience with stepper before. My machine used Omron CQM1 CPU 43. The driver is Prime type model 2D33MA. Sleepy Wombat, I found the stepper used PLS and ACC. Your help much appreciates Thanks
