Guest MalcomMelon Posted February 13, 2004 Report Posted February 13, 2004 (edited) I'm working on a job that is using CC link, Profibus to ET200S and E900 HMIs and AS-Interface. I think I'm OK with the CC link but as for the profibus and AS-Inteface I'm not so sure. I know that you have to use GX developer DP to configure the Profibus and that the node data on both the Profibus and ASi is avalible via the buffer memory(using to and from instructions). Also I'm using GX developer 7.0 with labels and function blocks, are there any known problems with using them? Any advice would be greatful. :-8 Just I case the CPU is a Q02CPU Edited February 13, 2004 by MalcomMelon Quote
