sparkotronic Posted February 11, 2009 Report Posted February 11, 2009 Hi all, I've just been giving a project to do in work. It's basically a batch weighing machine. I'll be bringing the Weight into the PLC via a load cell amplifier to an analogue card. Is there anything that I should be looking out for, I'm more of a S7 300 kind of guy and have very limited experience on the 200 range and software. Regards, Colin
Clay B. Posted February 11, 2009 Report Posted February 11, 2009 You may Simplify it a bit. Siemens makes a weight module called Siwarex MS module. This module comes with the ablity to handle your batching functions. If you have to use more than 1 load cell then you can combine your load cells in a Siwarex JS box. Depending on the resolution you need, a converter can become an issue. Contact your local vendor for more info. These modules have alot of built in features that make building a system alot easier.
sparkotronic Posted February 17, 2009 Author Report Posted February 17, 2009 I had a look at these and they would be brilliant if my employer would part with the cash! Unfortunately it's one of those odd's and sod's jobs where I have to use whatever I can find lying about. Still, I'll keep them in mind for the next time I get a project like this. Colin
