Hello All Does anyone know if its possible to configure an analog output card to send out a definable mA rating under fault conditions. I need to send out 12mA to a proportional valve for example if the plc goes into stop or if something goes wrong with the analog card internally regards Shamus
Hi Shamus. Go to the HW Configuration of the analog output card. Change the parameter Reaction to CPU STOP from the default OCV to Substitute Value. Then set Substitute to 12 mA. Dont think you can do anything about "if something goes wrong with the analog card internally".
Thanks JesperMP I've looked at that setting but it only seems to be giving me options of OCV (no volt or current) or KLV keep last value. I'm using a 6ES7 322-5H00-0AB0 regards Shamus
