ModeManuel Posted March 25, 2009 Report Posted March 25, 2009 Hi, I'm trying to use this instruction as a hudge compare (multiple words) ... it work the purpose is to know if someone change the value in a table of 30 bytes or 15 words it work well but I don't know why it stop working at bytes 24 the code is str sp1 ld k1E ( step 1) ( number of bytes hex) ld kF (step 2 )( lenth of table words hex ) lda o2016 (step 3) (ending location) lda o2000 ( step 4) (starting location) findb v2303 (step 5) (starting location of block) and sp53 (logic error flag) out c4 ( On= block not found in table, off= equal) step reference to the instruction chap. 5 it is hard to explain why but, if bytes 0 to 24 starting at v2000 are not equal to bytes 0 to 24 starting at v2303 the flag logic error sp53 is on ...yes good ! but bytes 25 to bytes 30 won't affect sp53 any one know why ? thank for your anwser
b_carlton Posted March 26, 2009 Report Posted March 26, 2009 I have used AutomationDirect products including this one but have never used this command. Your arguments look proper according to the documentation. Why don't you try posting at the AutomationDirect forum? You may get better answers there.
ModeManuel Posted March 26, 2009 Author Report Posted March 26, 2009 Hi, you're probably right, I'll gave you feedback on this .... thank for your check
atanas Posted April 1, 2009 Report Posted April 1, 2009 Hi ModeManuel, Perhaps it has something to do with the numeral systems. 30 octal = 24 decimal. The octal numeral system is native for PLC Direct. Your code looks OK- adjust the constants Regards, Atanas
b_carlton Posted April 2, 2009 Report Posted April 2, 2009 Nothing much more to add except that I replicated your findings with the FINDB command on a DL06
b_carlton Posted April 6, 2009 Report Posted April 6, 2009 ModeManuel - did this get resolved. I didn't note any postings on the AD forum. I haven't used this instruction before but if I do I want to know any official limitations that AD may have which aren't in the manuals.
ModeManuel Posted April 30, 2009 Author Report Posted April 30, 2009 Sorry if I didn't gave you feedback before ... I didn't post on the plc direct forum like expected and I finaly had enaugh to make it work even with that restriction. I shortened the recipe name lenght from 30 char to 24 thank's for you're help
