eziccc Posted April 9, 2009 Report Posted April 9, 2009 Hi all! I want to use OnLine Change function in my GX IEC Developer but don't know how! I think it mean - to change the project during PLC is running, isn't it? Please help! Thanks.
Gambit Posted April 9, 2009 Report Posted April 9, 2009 There are two methods. online change mode / project online change online change mode: switch to online mode. change a network then select new network( then the change will be made) project online change: just change theproject as you would do off line but do not compile. under project select project online change
eziccc Posted December 21, 2009 Author Report Posted December 21, 2009 It's OK (1st method) when I use Ladder Diag (LD). But when I use STL and use 2nd method but it don't takes effect! GX says something about "can't do online change to unsaved POU". ??
