Guest strattus Posted March 1, 2004 Report Posted March 1, 2004 Hi guys, I am learning to work with the mitusubishi sofware. I have to input 4 "T type thermcouple readings, average them and check the average with a constant value.can you guys pls help. Thanks, Karthik Quote
panic mode Posted March 1, 2004 Report Posted March 1, 2004 (edited) Hi Karthik/Strattus Welcome to this forum. I am sure everyone will be glad to help, but you need to do the first step. Nobody will develop whole program/solution for you. You need to start with something and once you get stuck, explain what happens, post your code and we will try to help with specific problem you have. There are some tutorials and articles in this forum on Mitsubishi programming and temperature control. http://www.mrplc.com/kb/ See if this helps and then if not, feel free to ask. Just be specific. Edited March 1, 2004 by panic mode Quote
