Using GX IEC Developer 6.00 I must admit that Im a newbee with the Mitsubishi environment. Anyway, I got a project imported (MELSEC_IL) and thougt that converting it to ladder would get me going... is there any way for doing that? thanx... alex
This is a problem that many people come across using GX IEC Developer, unless the program has been written in GX IEC in the first place AND the symbolic code was downloaded to the processor, you may only read the code back in Melsec IL. If the PLC was not programmed with IEC, you may be better off programming with GX Developer, GPPWin, or even DOS Medoc, as with these editors you can switch between list and ladder.
