Guest pawelleg Posted March 4, 2004 Report Posted March 4, 2004 Hello ! Dear members of MrPLC Forum! I have strange problem with my PLC Q12H, maybe somebody can give me some help. Problem is that inputs which are on state "1" what i can see in online mode are with state "0" on input to function it means that they don't affect on the function there is still "0" even if i check variable tabel in online mode there is one but as a input to function "0". Do you maybe know where is the problem. This is normal digital input. I have Mitsubishi modules and Simens IM 153-1 modules on Profibus. These from Mitsubishi are ok they change program status only something is wrong with those from profibus connection. Any suggestion is very welcom, i stuck with it and cannot do anything forward. Configuration: PLC: Q12H Profibus modul: PB92D Software: GX IEC Developer 6.0 Baudrate: 1,5 Mbps Thank you with advance Pawel S. Quote
panic mode Posted March 7, 2004 Report Posted March 7, 2004 It looks like you didn't set Profibus correctly Quote
Guest Guest Posted March 8, 2004 Report Posted March 8, 2004 yes, it looks like. probably rack configuration is wrong, i have to check it once again with manual Quote
