Guest Posted November 2, 2003 Report Posted November 2, 2003 View File Direct Input Fuse Failure Cad Drawing Here is a simple wiring diagram drawing showing a method of fuse failure detection using direct input. Of course you loose 4 DIs. If you AND all four fuses you can detect a PS failure (that with the fact that the PLC wouldn't work either if the PS su Submitter Guest Submitted 11/02/2003 Category Tutorials and Guides
