Guest Stef_pen Posted March 7, 2004 Report Posted March 7, 2004 i recently came across a unit of FX-232ah , it has two 25 pin female connector and it says rs232c / rs422 interface unit. whats the use of this unit? Quote
panic mode Posted March 7, 2004 Report Posted March 7, 2004 Just what you wrote - interface to other equipment using RS232 or 422. This other equipment can be pretty much anything such as barcode scanner, touchscreen, other PLC, PC, printer, ... anything. Quote
