Guest spt Posted March 11, 2004 Report Posted March 11, 2004 hello, I have two plc tsx micro with TSX ETZ 410. I can´t communicate this plc's in ethernet. Which is the syntax to communicate in pl7-junior. read_var(????) write_var(????) thank you, and sorry by my bad english. Quote
Crossbow Posted March 16, 2004 Report Posted March 16, 2004 I believe you have to use the MBP_MSTR command. It's Modbus/TCP ethernet. I don't have a sample code or books with me. Quote
Guest lazy Posted May 23, 2004 Report Posted May 23, 2004 you need to use the "send_req" function. if you want to e-mail me i can send you a powerpoint that will explain how the send_req works. my e-mail is wiltshirecomputing@eircom.net Quote
Chris Elston Posted May 23, 2004 Report Posted May 23, 2004 Lazy, Can you share your power point by posting it in the download section? http://forums.mrplc.com/index.php?act=Downloads&CODE=04 Others might benifit to. Thanks for your help! Quote
