Guest bbatcu2 Posted March 13, 2004 Report Posted March 13, 2004 Hi there, Where can i find a working version of GX Developer (one of the latest versions0 i cann`t work with the demo version. Tia bart Quote
panic mode Posted March 13, 2004 Report Posted March 13, 2004 Where did you look so far? Did you try contacting Mitsubishi distributors? Mitsubishi website is www.meau.com Quote
Crossbow Posted March 16, 2004 Report Posted March 16, 2004 Well if you can't work with the demo version, you should contact a distributor and buy a copy. GX-Developer is not overly expensive when compared to Modicon or Allen-Bradley. Check www.meau.com for the nearest distributor. Quote
