panic mode Posted February 13, 2009 Report Posted February 13, 2009 AutoPlay for CDs (autorun.inf) View File if you have tried to make own cd with autoplay you may have noticed that AUTORUN.INF only works on executables (exe or bat for example) but what if discs with data you want to share with customers for example only contains documents like presentations spreadsheets PDFs etc.? one can easily make BAT file with START "MY_DOCUMENT" but the downside is that command line box shows up during loading etc. there are numerous programs on the internet that can take care of that but all i was able to find was not free (well it could be there i didn't look too hard). this is why this little program is made. it is based on ShellEx API it's simple to use simply specify inside INI file what document you want to open when disc is inserted and edit AUTORUN.INF to be something like this: [AutoRun] OPEN=AutoPlay.exe ICON=Icon.ico note that AutoPlay.exe looks in AutoPlay.ini for line OPEN= and file name should be enclosed by quotation marks for example OPEN="My Presentation.ppt" or "New Developments.pdf" also AUTOPLAY.INI must be in same folder as AUTOPLAY.EXE to make your disc start properly when inserted you need: 1. AUTORUN.INF 2. AUTOPLAY.EXE 3. AUTOPLAY.INI 4. end user PC that don't have autoplay feature turned off (sorry can't control everything) and before i forget: AutoPlay.exe does not handle your files. it simply tells Windows to open them. in other words target pc should have installed software to handle specified file type or the moment of glory will be...well without glory... good luck Submitter panic mode Submitted 02/13/2009 Category Free Utilities
