lightfornight Posted June 3, 2009 Report Posted June 3, 2009 hi everyone. i have a problem with mitsubishi fx1n PLC and delta tp04g HMI. i need to make communication between PLC and HMI but i cant. i try every method but i doesnt work. what can i do for make this. is there any people can or could this communication. i will wait for your response excitemently. thanks
Gambit Posted June 3, 2009 Report Posted June 3, 2009 (edited) Is there a tp04g forum? How are you connected to the PLC? CPU port or BD board? Edited June 3, 2009 by Gambit
danieluy Posted June 4, 2009 Report Posted June 4, 2009 Using TP04G with Mitsubishi is normally used using RS-485... you have to set the Comm Parameters properly... you can download the programs from the Delta Website... http://www.delta.com.tw/product/em/control...or%201.10.8.zip there is no user manual for TP04 but all is descriibed in the TP04 help file... The samples are using Delta PLC but Delta PLC and Mitsubishi addressing are similar... so it shouldn't be much of a problem
