damirpetrinic Posted March 17, 2004 Report Posted March 17, 2004 Helo to all, I'm Damir Petrinic, Marine electronic engineer, working on dynamically positioned heavy lift vessel Saipem 3000 as maintaining electronic engineer. Just recently I receive FX0-14MR plc. I'm asking for help ,information about software and cable to work with this PLC. I'm already receive cable schematic and download Melsec Medoc FX/Win ver 2.0 demo but I'm not able to made communication with PLC. Do I neeed to take care about some special parameters or? Any suggestions? Any help will be appreciated. Thanks in advance. Quote
Crossbow Posted March 17, 2004 Report Posted March 17, 2004 I believe the demo version was not allowed online. You should try the old DOS MEDOC program and see if you can communicate. Be aware that the built-in comms for Mitsubishi PLCs is RS422, and the cable Mitsubishi sells has an RS422-RS232 converter in it. You may also want to go to www.meau.com and download the demo version of GX-Developer or GX-Developer-FX, as they are the current software. The FX version is limited to all FX series PLCs, where the full GX-Developer will talk to A, A1S, and Q PLCs as wel as FX. Quote
