Guest pawelleg Posted March 18, 2004 Report Posted March 18, 2004 Hello ! I need some help !!! I have problem with correct parametrization between Melsecnet QJ71BR11 module and two displays A975GOT connected by interface J17BR13. How such system should be parametrized, somebody maybe know it? I have comunication between Displays and Melsecnet module but i cannot see any signal from PLC on it!? I check several times, range of LB, driver of display, all looks ok but maybe any suggestion? Best Regards Pawel S. Quote
