cadomanis Posted March 19, 2004 Report Posted March 19, 2004 Does anyone have any experience with the Q series motion platform. I am considering implementing it as part of our motion control system, but I have some questions about the use of the cam profiles function that my local distributor is unale to answer. In particular, I am looking to use it to do some hydraulic control with servo valves and MDT feedback devices. Help! Chuck Quote
Guest Guest_Peter Nachtwey Posted March 20, 2004 Report Posted March 20, 2004 Do a Google search for hydraulic motion control. You will find there are hydraulic motion controllers build to do exactly what you want but you will need to be able use use Profibus DP. Quote
maccxim Posted March 27, 2004 Report Posted March 27, 2004 Take a look on this co-processor module of Mitsubishi Electric. Dedicated also for hydraulic applications. It use two slot on plc rack. I know some blow molding applications using servo valve control with feedback devices controlled by these modules bye Max SPAC_module.zip Quote
