eziccc Posted January 14, 2010 Report Posted January 14, 2010 So, in my GX Configurator I cofigured "D/A conversion enable/disable setting", "auto refresh -> D0". But howto make enable module's Y1 (CH1)? By switch? But I have 5 switches and don't see anything like output enable/disable flag. I think it's possible to ON module's Y1 by my program (I use Q01CPU), but in manual I found "If these are turned ON/OFF by the sequence program, the functioning of the D/A converter module cannot be guaranteed." Help! Thanks.
Crossbow Posted January 14, 2010 Report Posted January 14, 2010 You need to program the Y1 address as an output in your program. Connect it to input SM400 which is always on if you want.
