Modicon has several products called "Micro".....do you have the part number? Modsoft will only function with the older Micro-84 and the Micro-984, it will not work with the TSX micro.
Marjan, Actually I misspoke when I stated that Modsoft would work with the regular Micro-84 it will only function wtih the Micro-984. For the Micro-84 there was a software package called DMC that you could use along with the RS-232 conveter (J-375). On the Micro-984, simply use the Modsoft as with any 984 using Modbus to the 9 pin connecter. There is a compare function where the program within the PLC can be compaired to the offline one.
