papa francisco Posted February 18, 2010 Report Posted February 18, 2010 Initially I am receiving a 6 charatcer string with a CR/LF as the end character. Immediately after the CR/LF more data is sent. Unfortunately the data string is larger than 255 bytes. I am using two RXDU commands with different address locations. I was thinking that after I receive the first CR/LF that I would set a latch to enable the second RXDU command with a different address location. The problem is The data I need starts at the 254 byte mark but it is not consistent. Is there anything I could do to capture this data?
Sleepy Wombat Posted February 18, 2010 Report Posted February 18, 2010 since you are using the SCU21 then i would suggest that you look at the Protocol Macro function used in conjunction with CX-protocol.
