BenJones Posted February 25, 2010 Report Posted February 25, 2010 (edited) Hello all, I've been trying to program a counter for a while which can count the pulses from a water flow rate meter. The flow meter measures between 2 and 20 litres / minute and gives out a pulse train frequency of between 22.5 hz and 225 hz which correspond subsequently to these flow rates. I haven't programmed a counter before so not sure how best to do it. I've looked at functions for the high speed processing like the speed function (SPD_M) and also the HSCS and HSCR (High speed counter SET and RESET) but not really sure how best to use these. I can wire the meter to input X0 which can use a high speed counter and I think this corresponds to C235. I've been trying to use the SPD counter with "water flow pulses" (X0) on pin s1 and 1000 (ms) on s2 so that it looks at the amount of pulses in 1 second and then output to d (pulses per second). I could then work out the Litres / Min with a linear multiplier. The output of this SPD function takes an ARRAY of word length but not sure what this is. When I monitor it is says "structure" and I cant see any data in the chosen d register for pulses in a second when I look in the registers. Any ideas of the best way to program this ? I think I'm making life hard as this should be very straight forward, Many thanks for any input, Ben Edited February 25, 2010 by BenJones
Inntele Posted February 25, 2010 Report Posted February 25, 2010 Hi Ben, See this topic http://forums.mrplc.com/index.php?showtopic=18267
BenJones Posted February 25, 2010 Author Report Posted February 25, 2010 Thanks INTELLE ! I'll have a good read through Ben
BenJones Posted February 25, 2010 Author Report Posted February 25, 2010 Hi INTELLE, That looks like exactly the kind of thing I'm after ! Is there any way to upload that logic (in the pdf file) into GX IEC Developer and view it as ladder logic in a diagramatic kind of format? I find it hard to read this kind of instruction list program. Thanks, Ben
BenJones Posted February 25, 2010 Author Report Posted February 25, 2010 Would it not be easier to use the SPD function like KAARE explained in the earlier post ? If I used this, I'd have X0 on s1 (BOOL input), k1000 (ms) (1 sec) on s2, and "output pulses / sec" to d. Is that not correct ? The thing is I dont understand how the program saves to "d". Is this as an ARRAY ? It doesn't seem to simply save the numbers per second as an integer in a d register. It says "structure" when I monitor it and I don't undertand what this means. Thanks again, Ben
Inntele Posted February 25, 2010 Report Posted February 25, 2010 Ben, I'll try to find these programs on my PC, but I can to do it any later, because I'm a little bit busy now. Also I can do the appropriate function block for IEC Developer. Do you want to calculate current flowrate or total consumption, or both of them?
Inntele Posted February 25, 2010 Report Posted February 25, 2010 Of course, you can calculate frequency of pulses with SPD and then to multiply value for calculation of current flowrate. The output of SPD function is an ARRAY with two elements.
BenJones Posted February 25, 2010 Author Report Posted February 25, 2010 Georgios, Intelle, case closed ! Thanks, all sorted Cheers guys and may the UK get a gold in the olympics ! Ben
