Guest Tompa Posted April 19, 2004 Report Posted April 19, 2004 I have a question about the Mail Recieve (MRECV) instruction (GX IEC Developer) in the Ethernet module QJ71E71-100. I have maneged to recieve mails with the module but does anyone know what to do with the recieved e-mails? Can you for example make an Online change i some way or what is the meaning with this instruction. I can´t find an answer anywhere in the manuals. Quote
Patrik Posted April 28, 2004 Report Posted April 28, 2004 Hello tompa, As I've understand it you can only use the mail recieve function to recieve data, this data can be moved into e.g a string which can be used for comparing the mail-text with a predefined text.... Quote
