maccxim Posted March 4, 2010 Report Posted March 4, 2010 Anybody have expereance of plc programming by internet connections? For example: Q plc system with QJ71E71.. ethernt card connected in the factory network I had just one expereance using GX developer and a VPN connection Max
Inntele Posted March 4, 2010 Report Posted March 4, 2010 Max, There are not differences between direct Ethernet connection and VPN, if to talk about PLC programming. See menu Online-Transfer Setup, it seems there all crystal clear.
Crossbow Posted March 5, 2010 Report Posted March 5, 2010 Only issue with programming over the Internet is if the routers and firewalls at the site will let you in. That's an IT issue, not a PLC issue.
maccxim Posted March 5, 2010 Author Report Posted March 5, 2010 That's right but i've seen in the Mitsubishi internet site, GX Remote Service-I , version1 and version 2 package. Seems something that provides tools for internet programming .... ( .... i never used it Do you know something about it? Max
Crossbow Posted March 6, 2010 Report Posted March 6, 2010 Not released in North America. I know nothing about it.
Inntele Posted March 6, 2010 Report Posted March 6, 2010 I also first heard about this product, but after I read the materials I can say that this product is designed for remote access to the PLC, if the PLC is not directly connected to an Ethernet network, and connects to a computer on an Ethernet network via programming port.
maccxim Posted March 7, 2010 Author Report Posted March 7, 2010 thank you for your interesting I have found an old copy of Gx Remote Service. Seems a tools that provides a connection like this (PC with GX Remote Service)-----internet-----(Remote pc)----(PLC) the only thing i don't like of this configuration is that i must use Remote PC for connection. ........ I'm investigating
Inntele Posted March 7, 2010 Report Posted March 7, 2010 No need to complicate the task, plug PLC through QJ71E71-100 to an Ethernet, then configure the GX Developer connection on the remote computer and you can program your PLC remotely. Only may be some problem with online programming (when PLC run).
funfrok Posted March 8, 2010 Report Posted March 8, 2010 Hello, Can you give a link to this product, i couldn't find anything. Thanks
maccxim Posted March 8, 2010 Author Report Posted March 8, 2010 Use "GX Remoteservice-I Ver 2" with Google Or try to visit japan melfans web
