Ok, another problem. I am using a customer specd PLC direct EZ touch Panel EZ-S6M-FS. HMI info I cannot seem to get the two devices to communicate correctly. I have spent two days on the phone with PLC direct tech support and still no luck. I get the following error, "no communications" If I hit a button that simply toggles a bit about 50 times it will only toggle the bit maybe twice. It is suppose to work with all of the FX series plcs. I switched plcs to the FX1N and it worked great. Everything was purchased new. Has anyone ever used the two together. We've checked all the obvious items. No luck yet. Any ideas?
