Hello We got Equipment here with Mitsubishi FX-25DU connected to FX2n PLC. The Data Unit burnt up. I got the project send by Manufacture for this Data Unit to me. I can not open the file with my GT Designer2/Works2. There do not support FX DU Hardware. Anybody knows where I can find Demoversion or Download link for FXDUWIN (FX-PCS/DU-WIN-E). So i can test if the project I got works with FXDUWIN Software. Thanks
The project will open with FX DU WIN. The GT Works software cannot program the old obsolete FX-DU models. The software is also not free. You need to contact Mitsubishi to get a copy. MEAU is the support for these products. They can assist or tell you who your local distributor is. 800-950-7781 or tsg at meau.com
I purchase today FXDUWIN-C1 from Mitsubishi. Hope it will work with the Project. Will see in few days when i receive it. Thanks again Edited by THKAUTO
Good luck. Also make sure it's on an older version of Windows. I don't have the manual nearby to know which versions, but I don't think this software is newer than Windows 2000. Most likely wants Windows 95 or Windows 98.
I received the Software, works great also with XP-windows. But now I got Problem with the Cable for Programming the FX-DU HMI. I was told i need the FX-232CAB-1 Cable. But it is the wrong Cable. what Cable do I need for Programming the FX-DU unit? Do I need the F2-232CAB-1 Cable? Thanks
