Patrik Posted April 23, 2004 Report Posted April 23, 2004 Hello, My problem is that I have an array filled with words, these words do I want to move to a String for further use in the program, is there a easy way/instruction to do this? Best Regards Patrik Quote
Guest CodSystems Posted April 23, 2004 Report Posted April 23, 2004 You need to be more precise in what you want to do, and with what PLC type, as all types can have different methods. Regards, Nick Quote
Patrik Posted April 26, 2004 Author Report Posted April 26, 2004 I'm using the q system... I want to move Chararcter-information from an arrray of words in to a String variable...Then i want to compare the string with a predefined string... Quote
Patrik Posted April 28, 2004 Author Report Posted April 28, 2004 U can use the BMOV_E FB, this will solve your problem Quote
