Guest Turbo Posted April 27, 2004 Report Posted April 27, 2004 Hi for everybody, Has anyone knows about replacement of floppy driver 5.25 with floppy 3.5. We have an old type Toray Japon made plc which controls a winder and uses a monitor program and a 5.25 inch disk. How can I update this system to 3.5 inch floopy and a normal pc to monitor the program of the toray plc. Quote
larry818 Posted October 24, 2004 Report Posted October 24, 2004 You can probably just replace the floppy (if it's a standard pc type) with the 3.5" one and it'll work. The plc won't know or care that it's a 1.44mb, it'll just format and use it in it's native size (360K or 1.2m). Any pc (if it's formatted fat, which it may not be) should be able to read this disk. Quote
