Used Omron parts see list (like new condition) C200H-BC081-V2 RACK 8SLOT C200H-CPU01-E CPU MODULE PROGRAMMABLE CONTROLLER C200H-MR431 MEMORY MODULE 8K W/BATTERY C200HW-CLK21 CONTROLLER LINK MODULE R88D-UP10LA AC SERVO DRIVER S82K-05024 POWER SUPPLY 24VDC 2.1AMP OUT 13AMP 100/240VAC IN S82K-10024 POWER SUPPLY 4.2AMP 24VDC XW2B-20J6-1B SERVO TERMINL.FOR C200HW-NC113 C200H-MAD01 I/O MODULE 2 INPUTS 2 OUTPUTS ANALOG C200H-OC225 OUTPUT MODULE 16POINT CONTACT C200HE-CPU42-E CPU MODULE 8K W/RS232 880 I/O C200HW-BC081 BACKPLANE 8SLOT C200HW-COM04-EV1 COMMUNICATION MODULE W/BUS AND RS232 AND PMF C200HW-NC113 NC MODULE SINGLE AXIS STEPPER C200HW-PA204 POWER SUPPLY MODULE 120/240VAC STANDARD VERSION S8VS-12024 POWER SUPPLY C200H-ID212 INPUT MODULE 24VDC 16POINT C200H-OC222 OUTPUT MODULE RELAY 12POINT E2E-X5E1 PROXIMITY SWITCH E3S-CL1 PHOTOELECTRIC 20CM ADJ SENSING DISTANCE PNP/NPN S82K-03024 POWER SUPPLY 24VDC 1.2A OUT 100-240VAC INPUT E2EL-X2F1-M1L PROXMITY SWITCH 10-35VDC 200MA
