whizzo944 Posted April 28, 2004 Report Posted April 28, 2004 I have uploaded a program from an FXo into Medoc. How do I import this into GX Developer? The import option in GX is greyed out. I am not a big fan of this bit of software, it's a bitch to use!!!
JimRowell Posted April 28, 2004 Report Posted April 28, 2004 To import a Medoc dos project into GX Dev, you need to create a new GX project first. On the main menu select "Project | New Project". After that you'll see that the import option is no longer greyed out. If you have a copy of Medoc, you could also just use it if you don't like GX. Don't be too put off by the dos factor. It's a pretty good program once you get the hang of it. Jim Rowell
Pierre Posted April 29, 2004 Report Posted April 29, 2004 This function MUST also have been selected when you first installed th GX software. If it was not then no ways but re-installing it will help you.
