Guest nikus Posted April 30, 2004 Report Posted April 30, 2004 CAN ANYONE TELL ME HOW I WRITE THE CODE TO PUT WORDS IN ASCII ON A E610 FROM AN FX Quote
Crossbow Posted May 1, 2004 Report Posted May 1, 2004 Are you looking to store ASCII text in the PLC and display it on the screen? All you need to do is put the ASCII codes for each character is sequential words and then select an ASCII display field on the E610 and tell it where to look and how many characters. Otherwise I would put the text in comments in the E610 and display the comments based on the status of a word or bit in the PLC. Quote
