Guest Ronald Schmetter Posted May 13, 2004 Report Posted May 13, 2004 Is it possible to equip a GE 90-30 PLC with their slave device net module IC693DNS201 and have it communicate to the following Omron server? Server: Omron- made Open Network Controller Application Software: Omron-made ITNC-DL1Q-CD-V2 Data collection/distribution software PLC for Weathering Devices: Omron-made C200HS+C200H Quote
Guest Mike Huang Posted May 17, 2004 Report Posted May 17, 2004 Hi, Ron, It's Mike of Atlas. Glad to see your post here. At the first glance, I was a little surprised at the title of the posting. Then I realize you post it. I probably did the same thing you did with Google. So I end up see your post here. I've spoke to Horner people who provide a module called DeviceNet Slave, that is designed for GE 90-30 to communicate via DeviceNet. It seem to me it works from our end but I'm not sure about the other end which is Omron's server. So I want to search the web to get more info on that server and software application. But not much available. How is your recuperation? I wish you have a speed one. Mike Huang Quote
