Guest ketaciturn Posted May 15, 2004 Report Posted May 15, 2004 Good day Everyone! I've a question regarding Panasonic AC servo motor 750W, with its driver MSDA083A1A, and I'm using it to run under position control mode. But i need to use the acceleration and deceleration time in my application... So, how to set the driver without changing the PLC program, so that it runs under position control mode but still have the acc/dec effect? Quote
Guest Stanley Leong Posted July 7, 2004 Report Posted July 7, 2004 For position mode, you have to use PLC to insert ACC \ DEC. Panasonic Driver can't do that. Thanks, Regards, Stanley Leong stanley_ae86@yahoo.com Quote
